Dimmable LED's
Can any one suggest, dimmable LED's or drivers which work with Fibaro FGD 211?
So long this is NO standard for the "dimmable LED" light sources the best advice will be make a test (use of the Fibaro Bypass and use of the "3-wire connection" can also help in many cases). Also try to select in first place the "dimmable LEDs" that advertising as "Triac (leading edge dimming mode) compatible".
    Thanks for the information.
