Virtual device main loop
I have been trying to add track position to a virtual device so the status is shown and the slider can be used to move to a position in the track.
It works but the interface updates jerkily.
Has anyone worked out if the main loop executes at exactly 1s intervals so this is just browser rendering and you have to live with it or if the loop executes at around 1s intervals so is not suitable for this purpose.
Overall track time works out pretty well.
5 answers to this question
Very interesting
Can you put the Lua code that you used , so we can take a cue from yours??
Greetings from Sicily
    No rocket science
    ui.lblTrackLength.value and ui.lblRemain.value are set by the squeezebox add in when the track starts or play restarts
    can't understand why the UI is so jerky
    because Fibaro use simple xml http request to update UI, XHR is great to refresh some part of a web page but a query that should take one second can take 10 seconds simply! for a good results should Fibaro must use a tcp socket but is not suitable for web integration (browser compatibility etc), they can use it with ios and android (but only in local i think). Main Loop is not accurate so, simply put a fibaro:debug() in it and see the result
    main loop is very unusable for me at this time because: garbage collector occurs randomly and reset global variable sometimes yes, sometimes no ! can't use at the same time socket in main loop and socket in a button of the same virtual device, I tried many things without convincing results
    /emoticons/default_icon_curve.gif" alt=":-/" /> but there are some bug in 3.560 beta, try a fibaro:debug(os.date()); and
    /emoticons/default_icon_sad.gif" alt=":-(" /> (seems good in 3.561 for A.Socha)
    I wait next beta update and I hope good surprises
    Noticed the random garbage collection. The main loop is just odd. Why have a loop that runs every second?
    look forward to something better.
