Controlling Wall Plug from dimmer?
JanJoh
Hello!
I have a dimmer module (FGD211, In HC2 I see ID:22) and I use a “two key” momentary switch, so both S1 and S2 is connected.
With the default settings, I can maneuver the lights with just one key, and I am happy
Now, I would like to use the second key (s2) to turn on/off the Wall Plug (FGP111, ID21) that I have in the same room.
Can this be achieved somehow?
12 answers to this question
Hello!
yes it can be possible if Your dimmer version is 1.9 or higher. Then You can program scene for S2
  • yes it can be possible if Your dimmer version is 1.9 or higher. Then You can program scene for S2
    In HC2 the dimmer is listed as Version: 2.2
    So, how do i map this?
    Advanced options for dimmer in HC2 -> parameter 41 there You can read what to do
  • Advanced options for dimmer in HC2 -> parameter 41 there You can read what to do
    Well, I am sorry, but i do not understand how to map this. I understand i need to do something with "ID 16" and assoc. group 3. But, I am not connecting the dots here?
    Parameter 41Scene activation functionality.
    The device offers the possibility of sending commands compatible with Command class scene activation. Information is sent to devices assigned to association group no. 3. Controllers such as Home Center 2 are able to interpret such commands and basing on these commands they activate scenes, to which specific scene IDs have been assigned. The user may expand the functionality of the button connected to inputs S1 and S2 by distinguishing the actions of keys connected to those inputs.
    For example: double click would activate the scene “goodnight” and triple click would activate the scene
    “morning”.
    Scene ID is determined as follows:
    Momentary switch (push button) (parameter 14 set to 0):
    Input S1:
    holding down ID 12 (option inactive in case of roller blind switch)
    releasing ID 13
    double click ID 14 (depends on parameters 15 value - 1 = double click active)
    triple click ID 15
    one click ID 16
    Input S2:
    holding down ID 22 (option inactive in case of roller blind switch)
    releasing ID 23
    double click ID 24 (depends on parameters 15 value - 1 = double click active) option inactive in case of roller blind switch
    triple click ID 25
    one click ID 26
    You have to make parameter 41 active and then write scene in Lua, here You have the code:
    %% properties
    XXX sceneActivation
    %% globals
    if ( tonumber(fibaro:getValue(XXX, "sceneActivation")) == YYY)
    then
    fibaro:startScene(ZZZ);
    XXX- id of Dimmer
    YYY - id of click (one click ID 26)
    ZZZ- id of the scene You want to use
  • You have to make parameter 41 active and then write scene in Lua, here You have the code:
    %% properties
    XXX sceneActivation
    %% globals
    then
    XXX- id of Dimmer
    Aha I think i am beginning to see the logic, but, that leads to another querstion. Can i send a "push the b button" command do the plug, or do i need to build the logic to find out what state the plug is in, and then send the opposite command?
    I have read one more time Your first topic and realized that You just want to on/off wall plug using dimmer's S2. You can use association and add wall plug to second group.
    To sum up please read dimmer instruction really carefully,there You will find all answers on Your question.
    Point IV in instruction is association
  • I have read one more time Your first topic and realized that You just want to on/off wall plug using dimmer's S2. You can use association and add wall plug to second group.
    Ok, So, I take it that I should use Dimmer -> Advanced -> Association -> Group 2 -> Setup -> Highlight the Wall Plug ?
    COrrect?
    Should I ONLY have the plug associated, or should I still include the HC2?
    WHat does the "View" in assoc. Group do?
    HC2 has to be still associated! In "View" You can check which devices are truly associated
  • HC2 has to be still associated! In "View" You can check which devices are truly associated
    Many thanks! It was indeed as easy as that!
    I will however keep your code exampel for the more advanced mwthod. I am certain that I will want to try that at some point!
    You are welcome
