janbe 1
Although the visual scene creator module is aimed to be easy and understandable, creating your first scene might not be that easy if you have no programming experience.
When I first got my HC2, the first scene I created was a 'Watch a movie' scene. The scene simply needed to switch on a light. This proved to be not that straightforward as I initially thought.
First of all, there are two types of scenes:
1. you have scenes that run once (when you trigger them)
2. you have scenes that run continuously in a loop in the background
In our example, we don't need to have the scene running in the background, the scene just needs to be executed when we trigger it.
Create a new scene and name it 'Watch a movie', make sure you uncheck 'Active Scene' (this will prevent the scene from running in a continuous loop in the background).
Goto the Advanced tab and start constructing your scene.
The first thing that you will notice when you play around with this scene builder is that you cannot simply add a light and instruct it to turn on. Every scene needs to start with a condition (IF) and according to this condition you can do something (THEN).
IF [condition]
THEN [action]
The condition in our case does not make any sense because we just want our light to switch on. However, your scene needs to start with a condition so we need to add useless and confusing logic.
Try this:
IF DEVICES [light1] == [off]
THEN DEVICES [light1] = [on]
Save the scene and click RUN (there is also a STOP button here, I will explain this later on). When you click RUN, Light1 should switch on.
Now, if your forgot to uncheck 'Active Scene' when you created the scene, and you were to turn off light1, it would immediately switch back on again (because the scene is running in a loop in the background).
You turn off the light by going to 'Devices', locate 'Light1' and click the OFF button. Clicking the STOP scene button will not turn light1 back off. This button is used to stop a scene from running while it is running. In our case, the scene is only running a fraction of a second so clicking STOP will not do anything. You can have very large and complex scenes that run over a longer period of time. In those cases, clicking the STOP button would halt a scene from continuing to run.
Back to our example. We got our scene working but consider an example where you need to switch on 20 lights.
THEN DEVICES [light1+light2+light3+light...] = [on]
This will work as long light1 is turned off but what if you manually turned on [light1]? The scene would no longer work unless you first turn off [light1].
You could change your scene logic to this:
OR DEVICES [light2] == [off]
OR DEVICES [light3] == [off]
OR ...
but this would become an unnecessary large scene logic.
As an alternative, you could fix this problem using a variable. A variable is basically something that stores information. You assign a value to a variable and you can check the value of the variable in a condition.
Goto the variables panel in the Panels section and add a new variable, name it one and assign the value 1 to it.
Change your scene to this:
IF VARIABLE [one] == [1]
Unless you change the value of the variable one it will always remain 1 so this scene will always switch on your light(s) when you trigger it.
