fibaro:log vs. fibaro:debug
I've been using fibaro:debug when I write LUA, but I have seen that many of you use fibaro:log. I have tried that but I can't find any log files?
Where is fibaro:log showing?
5 answers to this question
On the status bat of the virtual device. If you make sure you sleep the code
    I'm sorry, but where is the "status bat"?
    [ Added: 2013-09-17, 11:50 ]
    Ok, I found it, two more questions about this.
    1. Can i control how long the messages is being showed?
    2. Can I access the figaro:log history to see previous results?
    2. Can I access the figaro:log history topso see previous results?
    1. sleep your code shows for longer but is not precise or use a label so you can control/ persist
    2. don't think so but Andrew might correct this.
    Ok, here is another question about fibaro:log.
    Can you update another devices status bat?
    no you can't but as Robmac said, you can use label. You can update another devices label from your virtual device:
