[solved] dimmer not turning fully off via momentary switch
I'm running into an issue with my dimmer that I can't get my head around.
When I press the momentary switch my light doesn't turn off completely. The light stays on at about 5% or 10%. Though I can turn off the light completely via the HC2 interface without a problem.
I have the most basic setup. 2 way wiring and a conventional incandescent bulb. All the dimmer values are on default.
Any pointers where I might look for a solution?
Update
I attached a new brand dimmer yesterday. Didn't change any of the settings. Still the same behavior.
I'm on HC2 3.562 and the dimmer is on version 2.2.
Update 2
I've attached a different dimmer to a toggle switch and that setup works flawlessly. The light turns fully on and fully off with the flip of a switch.
I also noticed something strange. I have to triple click the momentary switch the get the double click functionality (= turn light 100%).
I'm lost... Anyone?
[ Added: 2013-09-21, 09:45 ]
My wild guess is that parameter 13 (Min. dimming level) is causing the trouble. The lowest value you can set this to is 1% but I'm thinking that if I could set this to 0% things would work just fine.
Solved
As usual the solution is plain simple. I had NO/NC mixed on my momentary switch. The fibaro manual doesn't say anything about this. Your circuit has to be NO and when you click it closes.
