Quikdav 15
Hi all
Here's what I noticed with main loop.
I have a virtual device. In the main loop, I request an ethernet card. Here is the code in the main loop :
HC2 = Net.FHttp("192.168.11.20")
response ,status, errorCode = HC2:GET("/api/xdevices.json?cmd=10")
fibaro:log("Status = " .. status)
if (tonumber(status) == 200) then
response = json.decode(response)
fibaro:setGlobal("ABO", response.T1_PTEC)
fibaro:setGlobal("CONSO", response.T1_PAPP)
else
fibaro:log("ErrorCode = " .. errorCode)
fibaro:sleep(5*1000)
After a few time, my code fails and I have errorcode=2. The only way to restart it is to click on the debug button and to stop it. The code seems to restart
So I used an other way to do the same. I use a scene with my virtual device.
I keep the same virtual device, I add it a button where I copy my code removing the sleep command. And I clean the main loop of the virtual device
Then I create a scene that is autostarted and run each 5 seconds and I call the pressbutton of my virtual device.
In that case, it works very well. I only have status=200 and no errorcode=2 !!!
So for me, there is something wrong that occurs with the main loop that is run each second..
Regards
David
19 answers to this question
