janbe 1
Hi everybody, I have a basic question about LUA scripting on HC2.
The code below should trigger the lua script if the value of any device of type doorSensor changes.
My question is: where can I find a list of device types. The naming that is used here (doorSensor) is clearly different than the ones specified
.ANSWER
I misunderstood. This does not work as I thought. I thought you could specify a device type here (like 'doorSensor' or 'binanySwitch') and then the code would be executed if any of your doorSensors or binarySwitches went off. This is not possible. In the above case, 'doorSensor' needs to be replaced with the ID of your device.
