JanJoh 1
Hello!
I would like to place an Aeon 4-in-1 in my main bathroom, along with two fibaro dimmer modules.
I would like to use LUA in order to bring the lights up to 25% if global var "HouseIsSleeping" is set, and 100% if it is not. And then turn the lights off 30 seconds after the sensor returns to "safe". (Yes, that counter needs to restart on every movement, i know..)
I am sure you understand the logic, I do not want to be blinded if i get up in the night to go to the bathroom.
But, I have read some threads to indicate that the aeon may be slow? Is that the case?
I figure i would run the scene with a 2 second sleep to make it pretty responsive?
Or, could i use a "Breach alert" to launch the scene?
