iPad unable to connect to HC2
I have downloaded the iPad HC2 app and it finds my HC2.
I then enter my credentials, I the get an OK message.
But after that I get No Connection message. the iPhone app works.
7 answers to this question
Maybe You got no connection,becouse Your iPhone is connected remotely and only 1 device at the same time can be connected to HC2 remotely...
    It can't be that, I haven't configured remote access.
    I have same problem, was working perfect before. Since update 3.560 I had this problem.
    It was working last week and now its not.
    I have the same issue as well. Iphones are fine. Can fibaro please address this.
    Do you have a complex password?
    Try changing it to a simpler one.
    Ok, I resolve problem with connection.
    Go to the Access Control Panel and clear access to the RGBW and WallPlug. iPad has problem with this two modules.
    Ok the problem just got worst..Now one of my iphone doesnt work. How do u remove the wall plug from access panel as there is no tab to cancel it. So now I have 2 devices that are not working ie Ipad 1 and Iphone4.
    [ Added: 2013-11-12, 10:36 ]
    sorry..iphone4 is alive again. Just the ipad1.
