Proper way to send a http-command to another LAN device?
What is the proper way to send a http-command from the HC2 to another LAN device, like an IP-camera?
The goal is to make a virtual device which can send a http-command to a Panasonic IP-camera. This command will enable or disable the camera's 'privacy mode' mode.
The commands to send is:
Enable privacy modus:
Disable privacy command:
Status privacymodus:
Return: 1 (Enabled)
Return: 0 (Disabled)
Return: -1 (No Func parameter)
Return: -2 (No Kind parameter)
Return: -3 (No Data parameter)
Return: -4 (Invalid Func value or Invalid Kind value, Unsupported feature)
Return: -6 (Error while writing to flash memory)
Return: -7 (Privacy button setting (enable/disable), changed while Privacy Mode was turned on)
Return: -8 (Upper data setting error)
Return: -9 (Administrator ID and password not set)
Return: -11 (Not accessed by administrator)
Thanx in advance!
4 answers to this question
Hi Lambik,
Not ignoring but there are a few samples on the forum. Proper is a tough question. If your question is which one is Fibaro way, I guess start from a.socha's posts.
    Question...
    Now I get data in variable CamResponse:
    Data:1
    How can I filter just the zero, or an other number which is send back, so I can make a if-then construction?
    As I mentioned before, I just taking little steps ahead in this programming thing...
    EDIT: or is there a way to compare a string?
    (like if CamResponse = "Data:1" then ....)
    In LUA you can do this with : string.byte (myString [, position])
    string.byte ("Data:1" [, 6])
    string.byte ("Data:7" [, 6])
    Thanx! it works!
    BTW, how can I compare a whole string?
    Like:
    if CamResponse == "Data:0"
    then
    EDIT: I used another function. The function returns a value with corresponds with ascii-table. Used 'string.sub' instead incombination with 'tonumber'
    This what I did:
    Global variable:
    PrivacyModus_AU with values -1, 0, 1, 2
    Main loop:
    Button:
    For switching Privacymodus On/Off (togglebutton)
    If anybody has suggestions, please do!
