Lauri 6
i was thinking, if I have 3 radiators in same room, or using wall thermostat (secure) at same room. How can I make LUA to keep the thermostats always at same level?
Same thing, if I'm using wall thermostat and want to try temperature, then it needs to affect danfoss thermostats also. I tried association groups but it didnt work this way.
I made simple LUA:
189 - is Secure thermostat
187 - is danfoss thermostat.
%% properties
189 value
%% globals
if (
( tonumber(fibaro:getValue(189, "value")) == 5 )
or
then
fibaro:call(187, "setTargetLevel", "5");
fibaro:call(187, "setTime", tonumber(os.time(t)) + 120*60);
This way I have to make scene for every temperature from 5C to 28C. Is there better way to disolve this?
