How to program a scene that will set the HRT4-ZW to 20C
Guest MarkJ
Guest MarkJ
Hi
How to program a scene that will set the HRT4-ZW to 20C for more then 2 hours.
I'm able to set the temperature via a scene to any temperature i like but I can not do that for more then 2 hours this seems to be the default. (seems timing is fixed)
I also have the impression that teh heating panel overrides the scene.
Alternatives via LUA are welcome if a blockscene is not possible?
Br Mark
Hi MarkJ
you can set the time and temp with two calls or if it is with a timer you can use the lua scheduler to set both with the same call.
if you look in the code of the scheduler the calls are embedded if you want your own scene
