Something cool to look forward to.
Integrating with Control4 already! Now just wait until we can implement it to. Fibaro Team get your sales talk ready
[ Added: 2013-09-26, 14:44 ]
    It looks like they want companies to actively use their API. So I think this is a nice opportunity to finalize the Fibaro Heating
    I already registered as a Developer, so we'll just have to wait and see now
    Bring it on! This would be an ideal solution!
    yep, one main thing missign with the heating panel of the HC2 is that it's acting like a rough mechanical thermostat.
    On a real thermostat like the nest, you can say "I want 20° at 6h40" an the nest, after some time will understand that your house takes 35 minutes to rise the temp from 18° to 20° and will start your heater at 6h05
    One other thing is that a real thermostat takes into account the inertia of your heating system. this means that when a heater is turned off, the hot water in your system will continue to raise the temp... cutting the heater when the temp is at 20, will give you a temp at 21° 15 minutes later. So a real thermostat is cutting off the heater before the goal temp is reached and is starting the heater before the temp fall too much.
    An image is worth thousand words:
    • 3 months later...
    Guest pmviana
    Why there isn´t anything like this
    for Fibaro?
    Best regards,
    PV
