UNIVERSAL BINARY SENSOR FGBS321 and Parameter No. 14
I would like to program the module UNIVERSAL BINARY SENSOR FGBS321 as explained in the guide:
"For example: double click would activate the scene" goodnight "and
triple click would activate the scene "morning" "
How should I do?
where I go to insert the value "id 14" or "id 15" in the scene?
Can you give me a hand making an example of programming?
Thank you very much!
[ Added: 2013-10-02, 11:52 ]
I created a scene of this type:
%% properties
9 sceneActivation
%% globals
if(tonumber(fibaro:getValue(9, "sceneActivation")) == 14)
then fibaro:call(129, "turnOn"); end;
9 is the principal ID the FGBS321;
14 is the id of the double click;
129 is the id of the Wall Plug
does not work.
where is wrong?
Thank You
[ Added: 2013-10-08, 16:36 ]
up
