Windows Phone app Beta
Any People want to test the Beta app?
36 members have voted
  1. 1. Any People want to test the Beta app?
    • For Windows phone 7
      5
    • For Windows phone 8
      32
I build a windows phone app with at the moment only the basic functionality:
  • Run scenes.
    Turn Lights On-Off and Dimm.
    Turn devices On-Off.
    Wattage OF Device and Lights.
    Speech for Lili (no accuray test, complete sentence has to be correct).
Also added location tracking, which is send to the HC and can calculate distance in Scene (at the moment can only update every 30 minutes).
Need to put Ip in the settings to get connect to HC.
NOTE: Still some bugs and not finished, but I like to share it!
That the App needs the IP address of your Home Center as it cannot connect through home.fibaro.com
  • Answers 79
  • Created
  • Last Reply
Many thanks..the client is looking really good. Any chance for the ability to pin devices to the start screen.
Nice work, thank you.
    Update coming tomorrow!
    Added:
    House Weather
    House energy usage
    Room energy usage
    Room main temperature
    Room main Humidity
    All native fibaro Device, room and sensor icons are now stored in the app for faster loading and less data usage.
    Custom user icons are not cached yet.
    Device Icons. User icons + native Fibaro icons.
    Updating for device icons when device is switched on or off
    (wall plugs still getting wrong icons but working on it
    /emoticons/default_wink.png" alt=";)" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" /> )
    New sensors in room view:
    *Door sensor
    *Motion sensor
    *Smoke sensor also support for new version
    *Temperature sensor
    *Humidity sensor
    Working on:
    Alarm panel
    Arming of devices
    Virtual devices
    [ Added: 2013-12-23, 09:38 ]
    Added possibility to start Adding / Removing devices to Home Center (Can't see the log yet)
    [ Added: 2013-12-23, 13:36 ]
    Some screenshots of the new version
    [ Added: 2013-12-23, 15:00 ]
    And the new home screen
    Hoi Steven,
    Looks great!
    Couldn't really test everything thoroughly. But that's where you guys come in
    /emoticons/default_biggrin.png" alt=":D" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" /> I updated the App. Now just wait until it is published. Looking forward to your responses!
    [ Added: 2013-12-24, 09:36 ]
    update here:
    Great Job. I install the new beta on a HTC 8x and Nokia Lumia 925. Works great, it's fast (faster than the Fibaro app on IOS). Nice new features. I hope the next beta support also roller shutter devices!
    The next step a Fibaro Windows APP for the tablet
    Thank you, I actually half implemented the roller shutter so will finish it when I get home after the Christmas days and update the App. Suggestions on where to implement it? In the room, or a separate roller shutter page?
    To bad I don't have any time to build the Tablet app at the moment...
    The update for this app is a huge Christmas present. Many thanks. Is there an update to be able to control the alarm functions?
    I actually did.
    Did some more the last few days:
    • Added Alarm Disarm and Arm Functionality:
      * Alarm pin is located in Settings. Changing this later to a User input at the time of arming and disarming.
      * Visual indication if house alarm is armed, disarmed.
      Working on Arming and disarming sensors as well.
      Added correct icons including User icons for the Dimmable lights.
      Added possibility to wake up all dead nodes from settings.
      Now showing if a node is dead. When clicked, HC2 will try to do a wake up.
      Updated Scene Icon, now the difference between lua scene and graphic scene icon shows correctly.
      Wall plug Icon now changing color correctly.
      Temperature now updating correctly.
      Added Virtual Device Icons (still working on the device itself but don't have much time).
      Fixed Smoke sensor Font Size
      Fixed dimmable light wattage (with high values, the "W" would not be visible)
    I will throw out the update tonight.
    Wow your on fire this Christmas...alarm control...my missing link to finally complete my HomeSeer migration. If you PM me your paypal address I send you some beer money...to keep you going
    Excellent!!!
    Good Stevenvd
    +1000
    Thanks for all the compliments guys! Any ideas, mokups or suggetions for UI or anything just let me know
    /emoticons/default_smile.png" alt=":)" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" /> Gonne be busy after tomorrow so don't have much time but I will try to fit in any small things
    [ Added: 2013-12-31, 11:52 ]
    Fixed Window sensor!
    Had a mismatch somewhere which let rcanetta's app crash
    /emoticons/default_wink.png" alt=";)" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" /> He helped me find it.
    Are the updates due to be sent out...as I have not seen any since before Christmas.
    He yeah, I had a bug to fix and wanted to do some testing after words with something else. I think you should see the update tonight.
    Ok thanks
    if you go to the following link on your phone you should be able to update the app:
    Let me know how it goes!
    Many thanks for the update.
    Just a minor issue for some reason on my 920 the information at the top of the screen does not scale correctly...see attached screenshot.
    ^Same here, also with Lumia 920.
    It is still in beta stage, I mean it is not available directly in the store?
    I will try to do a normal realease instead of a Beta.
    Further I will release a better designed and (hopfully) better scaling dashboard this weekend
