Virtual Device report power consumption
Is it possible to report power consumption of an virtual device via LUA?
[ Added: 2013-10-06, 20:32 ]
<--bump-->
Is it possible today?
Can i use this lua code for a qubino smart meter 3 phase?
I have made a virtual device with 1 button and added 3 labels.
Here is my code when i have changed the ID's.
function getIcon(watt)
 if(watt > 8000) then return 1049
 elseif(watt >= 7500) then return 1047
 elseif(watt >= 6500) then return 1046
 elseif(watt >= 5500) then return 1045
 elseif(watt >= 4850) then return 1044
 elseif(watt >= 4250) then return 1043
 elseif(watt >= 3750) then return 1042
 elseif(watt >= 3450) then return 1041
 elseif(watt >= 3350) then return 1040
 elseif(watt >= 3250) then return 1039
 elseif(watt >= 3150) then return 1038
 elseif(watt >= 3050) then return 1037
 elseif(watt >= 2950) then return 1036
 elseif(watt >= 2850) then return 1035
 elseif(watt >= 2750) then return 1034
 elseif(watt >= 2650) then return 1033
 elseif(watt >= 2550) then return 1032
 elseif(watt >= 2450) then return 1031
 elseif(watt >= 2350) then return 1030
 elseif(watt >= 2250) then return 1029
 elseif(watt >= 2150) then return 1028
 elseif(watt >= 2050) then return 1027
 elseif(watt >= 1950) then return 1026
 elseif(watt >= 1850) then return 1025
 elseif(watt >= 1750) then return 1024
 elseif(watt >= 1650) then return 1023
 elseif(watt >= 1550) then return 1022
 elseif(watt >= 1450) then return 1021
 elseif(watt >= 1350) then return 1020
 elseif(watt >= 1250) then return 1019
 elseif(watt >= 1150) then return 1018
 elseif(watt >= 1050) then return 1017
 elseif(watt >= 950) then return 1016
 elseif(watt >= 850) then return 1015
 elseif(watt >= 750) then return 1014
 elseif(watt >= 650) then return 1013
 elseif(watt >= 550) then return 1012
 elseif(watt >= 450) then return 1011
 else return 1011 end
thisId = 368
started = os.date("%Y-%m-%d %H:%M:%S")
fibaro:debug("-- ["..started .."] Function Start --")
HC2 = Net.FHttp("192.168.10.187")
rwatt, status, errorCode = HC2:GET("/api/energy/now/now/single/devices/power/368")
rkwhour, status, errorCode = HC2:GET("/api/energy/now-3600/now/single/devices/power/368")
jsonTable = json.decode(rwatt)
jsonTable = json.decode(rkwhour)
watt = (jsonTable.W)
kwh = (jsonTable.kWh)
fibaro:debug(watt)
fibaro:debug(kwh)
time =  os.date("%H:%M:%S")
fibaro:log("Now: "..watt.."W | Last hour: "..kwh.."kWh")
fibaro:call(368, "setProperty", "ui.LabelNow.value", watt.." Watt");
fibaro:call(368, "setProperty", "ui.LabelHour.value",kwh.." kWh");
fibaro:call(368, "setProperty", "ui.LabelWhen.value", time);
fibaro:call(368, "setProperty", "currentIcon", getIcon(watt))
ended = os.date("%Y-%m-%d %H:%M:%S")
fibaro:debug("-- [".. ended .."] Function Ended --")
--fibaro:debug("Error: "..err)
fibaro:debug("Sleep 10 sec, then restart")
fibaro:sleep(10*1000)
