Controlling Domoticz from HC2
Hi, I'm a new user of HC2 and since I still use some switches controlled with a Rfxtrx433 and Domoticz I'm now trying to create virtual devices in HC2 to control them, but whenever I create a LUA code containing the text "&param" some characters gets deleted and only the character "m" remains, because of this the script don't seem to work
I have only tested this in the newly released version 3.570 so I don't know if this is a new issue or not, or if it's only me having this problem.
Example of the LUA code I use:
And this is how the code looks when I have saved it in HC2
Edit: I have now gotten the script to work but the code still looks the same after saving so it seems to be more of a cosmetical issue than a real problem
6 answers to this question
Samen problem here...
But it's also not working..
I have disabled authentication for the local access.
The problem is that the homecenter interprets the ¶ part of the string as a character entity. If you save it once and leave it alone it works. When you need to edit the url you need to fix the &param part again.
Can somebody export a setup for a on and off setup connected to xid 8 and server 192.168.1.13 8080 because I can't get my to work and what should I us in Fibaro link global or what?
Guest Hakanos
I am using this lua in virtual device to control my somfy blinds which is controlled with a rfxcom unit connected with domoticz and it's working great.
Domoticz = Net.FHttp("192.168.2.38",8080)
Domoticz:setBasicAuthentication("username", "password")
response, status, errorCode = Domoticz:GET("/json.htm?type=command&dparam=switchlight&idx=9&switchcmd=Off&level=0")
fibaro:log(response)
fibaro:sleep(3000)
if errorCode == 0
then
fibaro:log(status)
else
fibaro:log(errorCode)
I want to control some Nexa Dimmers that i have. I´ve managed to set up Domoticz on a Raspberry Pi, with a Rfxtrx433e
The following LUA-code for on and off(change "on" to "off") works great:
Domoticz = Net.FHttp("IP.Raspberry",8080)
Domoticz:setBasicAuthentication("Usr", "Pwd")
response, status, errorCode = Domoticz:GET("/json.htm?type=command&dparam=switchlight&idx=12&switchcmd=On&level=1")
fibaro:sleep(3000)
if errorCode == 0
then
fibaro:log(status)
else
Any tip on code to have a slider-button?
Hello, i use this example (in a scene)and i got an error:
Domoticz = Net.FHttp("192.168.0.122",8080)
response, status, errorCode = Domoticz:GET("/json.htm?type=command&dparam=switchlight&idx=8&switchcmd=On&level=1")
fibaro:sleep(3000)
if errorCode == 0
then
fibaro:log(status)
else
[DEBUG] 11:44:19: [1;31m2015-10-16 11:44:19.801726 [ fatal] Runtime error: /opt/fibaro/scenes/420.lua:1: attempt to index global 'Net' (a nil value)[0m
anyone an idea?
