Does somebody can explain me the difference with the new version ??
you mean FGR221 (2.1) and FGRM222 (2.2)?
    I mean beetween these 2 pictures.
    Shad, first is FGR221 (2.1) for mechanical
    second is our new product FGRM222 (2.2) (blind, gate controller, roulette for mechanical and electric)
    example as a blind
    Ok nice. Thanks you.
    Does this mean that Fibaro have now officially released a roller shutter module that works with electrical stop limit motors?
    amilanov, yes
    to pewnie o tej kostce pisałem w tym poście:
    PS.
    zostało jeszcze urządzenie z zapytajnikiem pokazane na targach w USA
    Guest merylion
    A.Socha: is this new model support 24V motors?
    For 24VDC motors I should have two output pins as motor has two wires and needs to swap polarity when changing direction
    @Merylion.
    The Roller Shutter 2 only works with AC motors - it is rated at 110 to 230V AC.
    But you do have a good question about the 24V DC motor. These are driven in different directions by changing the power supply's polarity. This is basically a DPDT relay.
    It would be good if Fibaro could develop this type of product.
    example as a blind
    Hi
    How is this product working to detect the end course of blind for electronic end stop motor ?
