Temperature alarm LUA sample?
I want to program an alarm system for my heater, and am seekingsome LUA guidance.
I have:
- One central heater device, controlled by a basic Fibaro switch
- One door/window temperature sensor near it, measuring temperature in the heater room
I noticed a situation where my switch "hung". According to HC2 it was off, but the physical contact was still closed ('ON'). I had to ON and OFF it once again, manually for it to really go off. This should never happen, but it did, and resulted in my heater almost exploding...
Simply put, I want to detect a temperature increase while the heater control device is off. So code should be something like:
variable "previous_room_temp"
variable "current_room_temp"
current_room_temp = read_temp(door_window_sensor) /* what's the temperature? */
if ((current_room_temp > previous_room_temp) AND heater = OFF) /* did it heat up while heater is off? */
then
send_alarm("dude, check your heater switch!") /* Help! */
previous_room_temp = current_room_temp /* store new temperature for future reference */
Are there any LUA guru's who can point me into the right direction by providing code to:
- read the exact temperature from a door/window sensor
- store this temperature in a global variable
Thanks,
Ronald
Guest Lode
When your heater doesn't shut down by itself when max temperature has been reached i would NEVER use something like this.
I've been reading this a couple of times from some other users but i don't understand the problem.
When my heater has reached the max temperature (set by user) it shuts down, it doesn't matter if my thermostat keeps asking for more. It's the build in sensor from your heater that should handle this.
    Sure Lode. I do agree. I have a pretty modern heater which I'm sure will shut of itself in case of overheating. However, even just for the sake of energy saving - it's a software effort 'only' to detect, alarm and an automated attempt to fix.
    Making progress with the LUA code here now. Fascinating that no-one seems to have something like this built yet!
