I have connected a fibaro dimmer to a switch which controls 4x LED lights. As the total power is less than 25W, i have added a bypass to 1 of the LED.
Even with the dimmer, the 4 LED lights are still flickering.
Any suggestions?
My setup:
2 wires setup.
Toggle switch
parameter 14 - 1
12 - 99
13 - 98
20 - 140
10 - 1
Switch controls 4x LED lights to go on or off together.
Try to adjust parameter 20 with a value between 130 and 135
feynman82, did you get it to work?
  • 1 month later...
What type of Lamps are you using?
Remember that dimming LED's can be tricky because there is a transformer in the mix. The Fibaro modules are Leading Edge, so with ELV Transformers the lamps can suffer from in-rush currents during the sharp 'on' cycle of the dimmer.
  • 2 months later...
I have the same problem. I have 3 GU10 LEDs and one E27 LED connected in parallel with a bypass to a dimmer. The total power is 26.5 W. Parameter 20 is default.
GU10 lamps flickered if they were switched on for a long time. After half an hour - no blickering at all.
I changed the parameter 20 to 137 and there was no flickering at all for several days.
Now it came back - GU10 flickers after they were switched on for a long time...
