Play Scene With Door Window Sensor
Swordpirat
i've try to use door/window sensor with a normal button for scene "go out home"....
i've associate window sensor with a button but....in advanced parameters i try to change parameters 15 but it don't change....and....as soon as i touch my button all lamps start to blink....
/emoticons/default_icon_eek.gif" alt=":shock:" />
/emoticons/default_icon_eek.gif" alt=":shock:" /> ...
someone use door window sensor with a button?
es
1 clic = start scene 1
2 clic = start scene 2
3 clic = start scene 3...
this is a great feature but ...no i ask here...because...
i 've employed 30 min to shut down all alarm in zwave network...!!
/emoticons/default_icon_evil.gif" alt=":evil:" />
Firstly You will have to exclude this door-window sensor from Fibaro alarm panel. Then You have to change parameter 14 or 15 (do not remember which was that but I can tell You it is the last one) when You change it for option "scene activation functionality" then You have to wake up this door-window sensor (open it and tap fast 3x tamper inside it) then refresh internet tab a viola You are ready to make scene for that
