Hi Guys
I just bought a fibaro System and I am stuck with a few problems.
First of all Fibaro System is great . Simple to use. I managed to get half of the XBMC Script from Shad working ( very nice work)... ok so where are the Problems.
Will there be some official XBMC integration in HC2 that would be amazing ?
1)I bought Vision Alarm siren battery VIS_ZM1601. This is recognized as a switch ( i can live with it ) but there are no special Parameters ( Maybe I have to add them Manually but as I say I am rather new ) but the worst is I doesn't detect the battery level how can i fix that ?
and How can I when my system is armed that the Siren goes off if somebody breaks in ?
2) I bought Ever Spring movement EVR_HSP02 Detector . I dunno but it does not work at all I sync it which works very nice , but how can I see that movement is detected , for me it is always the same . I tried to add manually some Parameters but doesn't work ( they disappear after saving so I assume I am doing something wrong ) But Even with the default Parameters it should work , shouldn't it ?
3) I read about the Gps bug in the Android Software , I found also the 1.2 Version but it is password protected . Is there a possibility to join the beta Tester somehow ?
4) I don't get lili to work , whatever i put it never recognized the phrase . Is there a how to Guide somewhere ?
5) Is there a possibility for the Ipad app to customize the Interface on what you are seeing and when ?
Wich problem do you have with my addon????
    Thanks Shad I will ask in the XBMC forum it's easier , so anybody could help me with the rest ?
    I just added a new Everspring HSP02 detector and for me it works. Did you wake up the device (keep klicking the tamper key) during inclusion when the HC2 asked for it?
    I can see the parameters but cannot change them. I can remember this was already mentioned on the forum. Notice that the default value for the re-trigger interval level (parameter 4) is 180 seconds. This means no motion will reported for 3 minutes after the detector is triggered.
    To my modest knowledge the HSP02 does not work fully with HC2. I own one. To be precise: it detects motion, but you cannot change the parameters. For an official explanation, see
    In short: Fibaro says it's an Everspring issue.
