with older HC2 version, I used to copy-paste the logs into excel and to do some analysis there (i.e. how many hours the heating had been running). Is there a way to export the same information in text format also in Rel. 3.x? alternatively, I think I need to integrate with a site such as thingspeak.com...
Riccardo
7 answers to this question
Guest Lode
I think there must be an API command to get this information.
I will take a look at it this evening.
[ Added: 2013-10-19, 11:36 ]
I did some research but can't find it.
I think it's stored in a json table but i don't know the api command to retrieve the data.
Maybe the fibaro guys can tell us.
    Thanks anyway..
    Anyone else has a hint on how to see a text-only log?
    Thanks!
    R
    you can use :
    from and to are unix timestamp.
    Steve
    thanks this works - it requires a lot of manual work in order to parse results in Excel though..
    Wondering if anyone is thinking about developing a "Heating Monitoring" application that takes this log and does some analysis on heating usage?
    Riccardo
    Guest Lode
    I love developing to those things but don't have much time now.
    I don't promise anything but i'll give it a shot.
    Riccardo
    If you send me some sample records I'm sure I can automate the parsing for you.
    thanks! I'm sending you an output in PM
    Have a nice evening
    R
