Axis Q7404 in HC2
Is the Axis Q7404 encoder supported in HC2?
5 answers to this question
Guest GG
I'm sure all Axis cameras and video encoders will work in HC2 as long as you use MJPEG.
Have a look att Axis VAPIX documentation
, page 12.
    Yes, i can now confirm its working out of the box. I haven´t still connected any actual cameras but i can connect to the Q7404 and it shows "no signal" in the HC2 GUI
    Guest GG
    It might be that you need to add some parameters to the default url in HC2 to be able to get video from channels 2 - 4, like ?camera=2 for video from input 2.
    Sorry if i wasn´t clear about it. The axis shows "no signal" if there isn´t any videosignal on the inputs. There is diffrent IP-addresses for each input so i don´t think i have to do anything but connect a camera to the inputs
    Guest GG
    OK, wasn't sure how this particular encoder worked. Some encoders have multiple inputs and only one ip-address.
