Raul 0
When I use json decode in main loop on virtual devices it stops working after a while and when I debug I usually get this error message: Expected value but found T_END at character 1.
Right now I'm getting this problem when I use the script below to see whats currently playing on my sat box (Vu+ Solo 2 with OpenPLI).
I had a similar issue when I used json decode to get temperature from Domoticz also, in that case I assigned a button to execute the code to work without problems. Anyone knows whats causing this and if I can add some code to get around this when it happens so the main loop doesn't stop?
6 answers to this question
