TV power consumption > 10 watt > e-mail notification
Hello everybody,
I created a new scene for testing which should send me an email if the power consumption is > 10 watt. In this case I used the wall plug from Fibaro.
I have two issue for which I have no answer.
A)
I received not only one mail if TV has been switched on. I receive dozens and more.
B) based on the attached screen shot I would like to know where in the settings of HC2 I can change the information marked in the red box.
Obviously I typed at the beginning of setting up the Zwave enviroment (6 months ago) something like "Rasensprenger an" -> "sprinkler on" but I don't know where to change this wording and/or to insert new "phrases".
Furthermore pls. find below the LUA code, although I solely work with the graphic.
%% properties
10 valueSensor
%% globals
if (
( tonumber(fibaro:getValue(10, "valueSensor")) >= 10 )
or
then
fibaro:call(2, "sendDefinedEmailNotification", "1");
I would be happy if someone can help me.
Best,
MagicT
6 answers to this question
Hello everybody,
Check this:
click on the puzzle tile (Panels), then click on "Notifications Panel". On the left (at the top) you find the "Notification List". There you can find all configured messages - you can edit them, or delete, or create a new on.
z-Tom
    Many thanks z-Tom,
    I inserted new messages. So problem B) has been solved.
    Has someone an idea what I have to change regarding the multiple messages I receive per email from the HC 2, see my scene and LUA code, which I posted unter A).
    Best,
    MagicT
    Try this :
    - disconnect the TV from the plug
    - set the level of power consumption to 1 (yes, one).
    Wait. Get you an email ? I think no. Plug the TV in the plug. Wait. Get you an email ? I hope no,too
    /emoticons/default_icon_smile.gif" alt=":-)" /> .
    Switch the TV on. Wait. Comes one email ? Or more ?
    Maybe the power consumption goes up and down and the Scene is due this often triggered - and than you get a lot of emails.
    z-Tom
    EDIT : An other idea : Try an old bulb (lamp) instead of the TV. What happens ?
    Probably the power consumption varies over time.
    You should have a variable like "powerTV", if the power consumption rises above for example 1 and powerTV is 0, send a notification and set powerTV to 1.
    Have another scene that checks if power consumption is < 1 and if powerTV is 1, change it back to 0.
    I have a similar problem aswell. I have created a scene for sending a push notification every time my washing machine is finished. Found out that it pulls 5 watts when it is finished and in standby.
    I created a scene with if <5 w then send push.
    Only problem is I get 10 or more notifications as long as the consumption is lower than 5. Tried making one with =<5 but the consumption is not that stable.
    Can anybody assist?
    Guest pablotibis
    hello, this is my scene below and to find out when the washing machine has finished, there are 3 variables to be entered in order to know if the machine is playing, stop and if I have already sent the push, because if not, sends push all the time.
    I control that if the watts are> 500 then the washing machine is accessa and if after drops below 3w then it means that it is turned off.
    %% properties
    18 valueSensor
    %% globals
    -- Cambiare id 18 per il dispositivo da monitorare
    local power = fibaro:getValue(18, "valueSensor") -- unità da monitorare
    local LavaOn = "LavaInEsecuzione" -- creare la variabile LavaInEsecuzione
    local LavaFerma = "LavaFerma" -- create a variable with name LavaFerma
    local push = "LavaPush" -- variable for push
    fibaro:debug("HC2 wash script stated: " .. os.date());
    fibaro:debug("Consumption="..power.." Watt")
    if (tonumber(power) > 500) then -- change to wanted value in watt
    fibaro:setGlobal(LavaOn, "1") -- sets variable to 1 if machine is running
    fibaro:setGlobal(LavaFerma, "0") -- sets variable LavaFerma to 0
    fibaro:setGlobal(push, "0") -- sets variable push to 0
    fibaro:debug("Lavatrice funzionando") -- lite debug text
    elseif (tonumber(power) < 3) then
    fibaro:debug("Lavatrice non sta funzionando.")
    fibaro:setGlobal(LavaOn, "0")
    fibaro:setGlobal(LavaFerma, "1") -- Lavaggio completo!
    if (tonumber(power) < 3) and fibaro:getGlobalValue(LavaFerma) == "1" and fibaro:getGlobalValue(push) == "0" then
    fibaro:setGlobal(push, "1")
    fibaro:debug("Send push message")
    fibaro:call(47, "sendPush", "La lavatrice ha finito alle: " .. string.format("%02d", currentDate.hour) .. ":" .. string.format("%02d", currentDate.min));
