Fibaro Flood sensor - scene
How to make two different scenes:
A) If someone mowes sensor - i will get notification that it has been moved
B) If there is flood - let me know that there is flood and also close water valve.
I have tried and if using block scenes and using breached - then scene will start always on both triggers flood and movement.
How can I get different scenes start to different triggers?
Lauri
11 answers to this question
As far as I know it is impossible now to make that scenes using block scenes
/emoticons/default_icon_sad.gif" alt=":-(" /> He have to wait till Fibaro will implement it in next versions of Home Center or somebody know the way to write scene in Lua.
Lauri, could you share block scene you are using with your flood sensor? I'll try to redesign it in Lua.
    No problem, but this one works with both triggers - doesnt matter if you move the sensor or there is actual flood.
    I would like to get both triggers. I tried flood sensor associated with wall plug and then I got it working.. if there is flood it turns on wall plug. I think I can use some virtual switch and associate this to flood sensor - and if switch is triggered - I will get notification - but I think it should be easier with LUA?
    Lauri,
    Thank you for sharing your script here.
    I made some investigation with my flood sensor. From my point of view, it's impossible now to distinguish different types of triggers - flooding and movement even with LUA.
    From LUA we can see just 'value' variable. It's set to 1 in breached state and to 0 in safe state. We can use it for triggering scene but cannot decide what type of trigger we have here.
    I plan to turn off movement alarm (via parameter 74) to avoid closing valves in case of just movement. When my FGBS-001 arrives I'll try to investigate more (I need FGBS-001 to connect to my Neptun valve control system).
    Skyroger2, that is not true, in LUA that is posible
    A.Socha, could you give clue for that? Which variable I should read?
    use
    on forum you got example - use search
    use
    i have searched and failed to find the thread before? i to have 2 x flood sensors and have to make sure no one touches them or the water stops!
    A.Socha, sorry, I'm pretty familiar with LUA, but still do not understand. Okay, fibaro:getSourceTrigger ():
    I'm getting:
    Maybe you have something undocumented in 'trigger', in addition to 'type', 'deviceID' and 'propertyName'?
    @Skyroger2 Did you manage to create a good LUA script
    Anyone figured out yet how to distinguish tamper alarm and flood alarm triggering?... or found out the clue behind A.Socha's message?
    use
    So far, I have had to deactivate the tamper alarm to avoid confusion.
