hvb83 1
I have the following code, through which I'm trying to make a LED-strip in the kitchen switch on and off based on a schedule.
In this case it should switch on every Saturday and Sunday at 7h30 and go through a series of colors based on timers. Since I want to be able to override it manually, this seemed the easiest solution to me.
Initially this worked without having the second time-check in (8h), but since I wanted to prevent the rule from starting also when I restart HC2 during the middle of the day, I build in an extra check to make sure that the timer will only start if it's between 7h30 and 8h.
And after that, it's not working anymore. It always states the if-statement is not true, even if it should be true. What am I doing wrong here?
10 answers to this question
