LUA scheduler for HC2 v1.2.9
This code is a LUA based scheduler that allows you to manage all timers from one scene.
It only runs when there are events to process not every 1 minute.
It replaces the loop/ get time/ if time is good then action then sleep. I do not know if it is more efficient than the blocks but it is more efficient than the standard LUA generated.
I have now tested with over 1000 actions and it runs fine.
WHAT YOU NEED TO CHANGE:
Insert lines in the marked section
luaDaySchedule:add(,, , , ,,,,)
THE TIME TO RUN:
sting representation of time in 24h format eg "23:21"
note: you can not use a global variable to vary the time of an event unless you force a restart of the scene
SUNRISE SUNSET + OR - MINUTES:
Schedules solar based events with + or - n minutes delay or advance.
"Sunrise" or "Sunset"
positive or negative number of minutes
ID OF DEVICE or SCENE :
string or numeric id of a device or LUA table of ids
WHAT ACTIONS:
switch a device on or off
set a dimmer value
send an email,
send a push notifications to all devices
send an email notification to all users
send a push notification to a device
send an email notification to an user
push a virtual device button
set a virtual device slider
set a global variable
arm or disarm a device
set RGB colour
set white level
set red level
set green level
set blue level
start program
run another scene
set target level
kill scene (1.1.1 not tested)
enable scene (1.1.1 not tested)
debug (1.1.1 not tested)
setThermostat time and temp at same time
getValue and store in global
+ as an example of own function
get remaining time and store in a global and
a function that stores n temperature sensors values in n globals
one of "call"
"setGlobal"
"startScene"
"pressButton"
"setSlider"
"setValue"
"sendEmail"
"sendGlobalPushNotifications"
"sendGlobalEmailNotifications"
"sendDefinedPushNotification"
"sendDefinedEmailNotification"
"setTime"
"setArmed"
"setRGBColor"
"setColor"
"setR"
"setG"
"setB"
"setW"
"startProgram"
"setTargetLevel"
"killScenes"
"setSceneEnabled"
"debug"
"setThermostat"
"getValue"
the value of any parameter needed for the action see samples in module for individual actions
You can define extra functions within the module and schedule when to run. See note
CATCH UP RECENT ACTIONS:
true or false
When restarting HC2 or editing the scene, the current state of all scheduled items is parsed so that the system plays the last action that should have executed prior to the current time. This will set all variables and devices to the state scheduled with no user interaction.
By default the code parses 24hrs of events to work out current state. Mark as true or false on action add to set to catchup or not.
The catch up works for devices, scenes and variables that are always controlled by the timer. The function works out what state the device, scene and variables should be set to at the time the HC2 is restarted or scene is saved and sets it to that level/value.
If the device is regularly switched manually you need to decide if you want to use the function as you may be better to leave the device in the last state or off controlled by the parameters on the device.
It works well for variables like isNight or timeOfDay. Good for heating and hot water as it makes sure the heating is on or off after the HC2 is restarted.
SCHEDULE ONLY CERTAIN OR ALL DAYS:
a LUA table of strings days of the week (in english though you could edit the module>
You can schedule Sunday and Monday for example by setting {"Sunday","Monday"} in the add call.
There are three specials
{"All"} = all days,
{"Weekend"} = Saturday and Sunday,
{"Weekday"} = Monday to Friday.
these can be combined with normal days
{"Weekend","Monday"} = Saturday, Sunday and Monday,
REPEAT:
the number of times to repeat starting with the scheduled time
the number of minutes between repeats
a value to increment the value by
You can schedule multiple/repeat actions after the initial action with a single line so you can slowly increase or decrease a dimmer or slider value.
On RGB controller you can slowly change colour and brightness with multiple actions using a single line.
Repeat does not work on events scheduled using sunrise, sunset, weekday, and weekend.
MORE ON HOW TO USE:
Usage is explained by example see comment --examples in code.
Copy code into a LUA scene and save.
Then add your own schedule lines using the examples as templates and remove the text
NOTE this version adds:
-- new functions for RGB setR setG setW setB and startProgram
If you have a problem that requires both a time and other checks using if this then else if then else if then else. Embed the if this then else if then else if then else in another scene and schedule that scene from the scheduler.
DEBUG:
You can get more/less info in debug window of HC2 but will only display so much due to window length.
Code:
local debugadd = false;
local debugcatch = false;
local debug = false; --solar
--prints when it runs to debug
local reportRun = true;
UPGRADING:
Back up your lines in a text edit program. i.e. the ones you have added .
Open the new file and paste your lines over .
Follow any instructions on how to edit lines given with release.
HOW IT WORKS:
The scene is set to autorun and will only run one instance.
On start all of the lines you have defined in the add section are loaded to a LUA table. Any lines that are repeated n times at an interval with a value increment are generated and stored in the same table.
The code then parses the table and constructs a list of actions to run to catch up. One event per device is then run to bring the system to the approximate state if the schedule was run unattended. Note the true false value on the add to define it the event should be caught up.
The sunrise and sunset events are calculated during the day so they adjust with the change in solar cycles. These are stored in separate tables.
The code then runs any event scheduled for now, calculates the next time to run and goes to sleep until needed again. If you have reporting on you will note a message reporting a time correction. This is a calculation to make sure schedule executes at the middle of the minute.
With run report flag set to true output is like this: (most of my events removed to illustrate the long sleeps and have a short list)
Code:
[DEBUG] 09:17:20: Catching up actions.
[DEBUG] 09:17:20: Event scheduled for 08/05/13 at 05:00
[DEBUG] 09:17:20: fibaro:setGlobal("TimeOfDay","Morning")
[DEBUG] 09:17:20: Event scheduled for 08/05/13 at 05:55
[DEBUG] 09:17:20: fibaro:setGlobal("NightTime","0")
[DEBUG] 09:17:20: Event scheduled for 08/05/13 at 06:00
[DEBUG] 09:17:20: fibaro:call(19,"turnOn")
[DEBUG] 09:17:20: Event scheduled for 08/05/13 at 08:00
[DEBUG] 09:17:20: fibaro:setGlobal("HotWaterHeat","0")
[DEBUG] 09:17:20: Catching up finished.
[DEBUG] 09:17:20: Next Run at 10:30:30
[DEBUG] 09:17:20: Correct by -10s error,
[DEBUG] 09:17:20: Going to sleep for 73mins
[DEBUG] 10:30:30: Schedule running at 10:30:30
[DEBUG] 10:30:30: fibaro:call(19,"turnOff")
[DEBUG] 10:30:30: Next Run at 12:00:30
[DEBUG] 10:30:30: Correct by 0s error,
[DEBUG] 10:30:30: Going to sleep for 90mins
[DEBUG] 12:00:30: Schedule running at 12:00:30
[DEBUG] 12:00:30: fibaro:setGlobal("TimeOfDay","Afternoon")
[DEBUG] 12:00:30: Next Run at 12:05:30
[DEBUG] 12:00:30: Correct by 0s error,
[DEBUG] 12:00:30: Going to sleep for 5mins
Known Issues : no validation on some values
11 answers to this question
Very nice post, Thank you
Useful, thanks
/emoticons/default_icon_wink.gif" alt=";-)" /> i have run this four a couple of weeks now and i think it very good .
Now i have bought an Aeotec 4-in-1.
I would implement this in the code special the light sensor .
When the light sensor tells is dark out it will switch on light but it will switch the light off with time 21:15.
In the morning it will switch on light with timmer 07:00 but it will switch off with the light sensor when the sun is lightning.
I wounder how it should done this.
Best regards
Johan
Hi Robmac,
I tried and implement a Off functionnality for the alarm clocks by just adding "Off" in the choice of days !
It s not as nice as adding an on/off button but it's quick to do and seems to work.
Lines modified in the code:
VD alarmclock
button to change days: added
line 14 and a coma at the end of line 13
added
line 28 and a coma at the end of line 27
modified line 33 as follow:
button to save: added
line 22 and a coma at the end of line 21
Scheduler scene: updated the function luaDaySchedule.days by adding line 574
and a coma at the end of line 573
I hope it helps.
Hi
i tried this but i' am new
made VD with VID413 Alarm Clock
made VD with VID414 Schedule Control
made scene with SID 412 Scene-1
made scene with SID 413 Scene-2
when i run this i get
[DEBUG] scheduler is intitialising. Loading whith profile group WinterNormal. --But i have set it on SummerNormal in Schedule Control VD
[DEBUG] initialise Alarm alarmTime2 in room woonkamer.
[ERROR] line98: attempt to concatenate a nil value -- this is the line -- fibaro:debug( "Initialise Alarm " .. i .. " in room " .. fibaro:getRoomNameByDeviceID(v.deviceID) .. ".")
another question
what i wanted to do is if time VID413 is as os.date("*t") then lights ID63 goes on.
    this is an old version
    is there a new version
    If 4.x use the version half way through that was for BETA.
    One way or possibly another there will be a new version soon.
    How should offesets to Sunset/Sunrise be specified? I tried
    luaDaySchedule:add("Sunrise-60", "151", "turnOff" , "call", {"All"},true)
    but that didn't work.
    In another forum I found an exampel with the same command as
    luaDaySchedule:add("Sunrise", "151", "turnOff" , "call", {"All"},true, -60)
    Which one is right?
    I also cannot get a list of ID's to work, forcing me to have a new .add for every id.
    Ie, I would expect the following to work but then the event is silently ignored.
    luaDaySchedule:add("Sunrise", { "151", "153", "155"}, "turnOff" , "call", {"All"},true)
    Great pience of addon to HC2 all in all!
    There is no code in this topic and the link for updated version is not working. Please delete this topic because is just a waste of time.
