ritchie.avena 0
Greetings to everyone! And to everyone...I need help.
I'm new to fibaro and LUA programming. So basically I have no idea how to make this work.
Here is my case, I have a fibaro HC2 and global caché WF2IR. I got the IR codes done and is sending it properly. Unfortunately, I am using 1 Button to send 1 IR Command. which you can imagine the range of 16-28 degrees for each fan speed of low, med, high, and auto.
Thats already 52 buttons.
I wanted to make it similar to the actual remote where it is using 1 button to alternate between fan speed, 2 buttons for increasing and decreasing the temperature, and a display/Label to indicate the settings sent.
I have the logic of the things i want to do but don't know how to do it in LUA.
I was thinking of just placing the IR Codes into a 2 dimensional array and switching in between them when button is pressed for fan speed and temperature. and simply sending the value from the array. that's it.. can you guys help me?
