Hi
I have installed the dimmer module based on the instruction provided on this page "http://www.vesternet.com/resources/application-notes/apnt-2#.Um9IQRBQi00".
I was able to successfully include the dimmer module in the zwave network and controlling the light from the controller without any problems however switching the light On and Off from the toggle switches is very erratic sometimes it works and sometimes it doesn't. What happens, when I switch the light On using the toggle switch the light remains Off while on the controller it shows that it's On so I have to adjust the dimming from the controller for it to switch on. Again if I switch it off from the toggle switch it remains on but on the controller it shows off. I noticed that if I recycle the power on the dimmer module the setup works for a minute and stops again.
Do you have any suggestions to troubleshoot this problem?
check firmware, if 1.9, then it's a known bug.
If you send them to fibaro, they upgrade them for free
Sorry, posted in wrong thread. Please remove this post....
Best regards
Håkan
I have the same problem with the dimmers 1.9 firmware. I must send it back to fibaro, but i installed more then 10 dimmers in the wall. A lot of work
/emoticons/default_icon_sad.gif" alt=":-(" /> And u can't use the light for a while.
Workarround: If you press tree times the toggle switch it's go on or off. Next time one press wil work until you press the other toggle switch. then you must first tree times press the toggle switch again.
