Problems with Minimote?
I'm getting this issue when trying to include a Minimote to my HC2 3.70.
[10] Home Center in learning mode
[10] Device added
[10] ID 71: Controller added
[10] Routing table update
[10] Learning mode error. Try again.
Has anyone seen or fixed this prob before?
Cheers, Jonny
10 answers to this question
I would suggest resetting the Minimote before you include it and see if that helps.
Have a look at this guide -
    Thanks Vesternet. I had a look through that guide already. However, I'd missed a trick.
    The key step was "Press & Hold Associate + Learn until the LEDs stop flashing". That's the magic.
    Thanks for your help!
    [ Added: 2013-10-29, 11:17 ]
    I'm trying to follow that guide (as well as other), but I cant get the next section to work ..... starting a scene from the remote event. I've made the simplest possible scene to test it :-
    when I run this scene via the UI, it turns on lamp (id 62), but it wont trigger from the remote. Anyone got any ideas?
    Thanks, Jonny
    [ Added: 2013-10-29, 12:39 ]
    Ok, I've fixed my issue!
    For other peoples benefit, I added the device again. Reconfigure succeed, but still didn't lead to sceneActivation working.
    I simply added the device again - without removing, but this time the debug console at the top of HC2 mentioned parameter 250 being set to 1, and hey presto all worked!
    Just to confirm for other users re-adding the device WITHOUT removing it solves the issue you correctly get a debug 250=1 in the parameters. This didn't seem to be a problem pre 3.570.
    Thanks for the info Jonny....saved me a whole heap of effort.
    With 3.571 the minimote can no longer be added tot the HC2. Support confirmed we have to wait for the new z-wave engine.
    I have a BIG problem with my minimote.
    Why ?
    The remote control is added, but the inclusion does not.
    I have a message that says a problem occurred during the entry into learning mode. Refresh the page and try again.
    It's just terrifying!
    I have every reason to believe that the first edition of this remote control is not supported. I am in firmware version 1.18 europe.
    The model of this remote control is DSA03202W-ZWEU
    I would greatly that it works for my wife it is very simple for her to use an application to open or close the gate.
    Many thanks for Fibaro techs !
    Is anybody successful in configuring Aeon labs minimote with HC2 3.581?
    Minimote adds successfully but, remains 'waitng for wake up' even after waking up(pressing learn button 3 times).
    Any help
    You should press it once for 3 seconds?
    Wow, it worked...thanks
    Does it work as a scene controller ? does it trigger scenes in HC or not ?
    I just got my HCL and wanted to try this
    Same issue for me in HS 3.590
    [12] Home Center in learning mode
    [12] Device added
    [12] ID 104: Controller added
    [12] Routing table update
    [12] Learning mode error. Try again.
    minimote was reset and added described on
    Wanted to use the mote to control my drapes.
