Videogate on TV
Guest imparator
Guest imparator
Hi, i have a question to the experts
I want to create some scene to do this
1. When the doorbell rings,
2 take a snapshot from my ip cam .
3. If TV is on then switch to input example camera on the marantz sr5007 receiver
Where my dahua Dvr output is connected , so I can see the video on the screen
4 and after 20 sec's go back to hdmi 1
My equipment is :
Philips TV 58 pfl 9956 connected on network
Marantz Sr 5007 connected on network
Logitech harmony ultimate
Is this possible ?
11 answers to this question
I would also be interested in such functionality...because the price for dedicated home entry systems from Helios is very high
I also have ip camera at my gate and want to put the stream on my TV if someone rings the bell
I've done this, using a Raspberry Pi connected with HDMI to the tv.
When triggered, my IP cam motion detection stores an image on the Pi. The Pi senses this and triggers a scene on the HC2. The scene uses a lua virtual device that tells my Samsung tv to switch channel to the Pi, open the Tv channel in a picture-in-picture and then switch back after 15 seconds.
I also have a scene that every 10 minutes makes sure that the IP cam stream is active on the Pi.
It's a little complicated design but works like a charm.
/CQ1
Or you can check to us xbmc.
/CQ1
Can You make some tutorial for us?
Use Android mini pc, install IP cam viewer app and configure IP cam for live view.
Use global cache itach IR gateway as virtual device and run scene to switch to required HDMI port on TV when some one rings door bell. Even u can add 'Mute' command for Home treater.
Not a full tutorial, but at least some more details
/emoticons/default_icon_wink.gif" alt=";-)" /> :
The Pi is attached to the back of the TV and connected with HDMI. It's running Raspbmc (XMBC for the Pi).
1) Controlling the tv
Here, Piotr's
was exactly to the point for me (Samsung ES8005). I've created a Virtual Device for the tv with various buttons - XBMC (that will push KEY_HDMI and switch channel to the Pi), TV (switches back again) and a key sequence of KEY_HDMI, KEY_PIP and KEY_TV.
2) Triggering everything on movement
If you want to trigger from your doorbell, I'd recommend connecting a Universal Binary Sensor. I opted to go for movement detection using the built in functionality in my Vivotek IP 8332 network camera instead.
When the camera senses motion, it stores a snapshot on a share exposed by the Raspberry Pi (seen as NAS by the camera). On the Pi, I've installed Incron (
) that is monitoring the file system for changes. When the snapshot JPG lands, Incron launches a shell script that runs the scene on HC2 that triggers the tv virtual device.
The shell script used to run a scene is just
3) Making sure that the Pi is showing the IP camera
Since the Pi is sometimes used for other things, I have a HC2 scene that runs with 10 minutes interval opening the camera stream in the player. That scene triggers a Virtual Device (oh how I love those virtual devices!) that basically contains the code below in a button:
Everything gets a little complicated when the camera can't (as far as I can tell) send a dírect HTTP call to HC2 when motion is detected, so that is why I have to use Incron.
Hope this helps you some.
/CQ1
CQ1,
You have very more easier than that with xbmc.
Just use my addon for xbmc and you vn have like 8 camera in xbmc, and only need to open 1 url with virtual device.
Guest imparator
    Shad, can i you rstp in your script ?
    CQ1,
    Yes rtsp work. But the script work with screenshot.
    Guest imparator
    Shad , i cannot let it work , i get script error , every time.
    can you give me a example , with a rstp line please ?
    i use a raspberry pi with xbmc
    when i use this in virtual device it works ok , but it plays fullscreen,
    tcpSocket = Net.FTcpSocket("192.168.0.156", 9090)
    bytes, errorCode = tcpSocket:write('{ "jsonrpc": "2.0", "method": "Player.Open", "params": { "item": { "file": "rtsp://user:[email protected]:554/cam/realmonitor?channel=1&subtype=1" } }, "id": 1 }')
    i want this in like your script , small screen below the film or music i play
    remove ":554"
