I have a lightswitch that looks like this to operate two individual lights. --> see image below.
The left switch operates my kitchen light on/off, the right switch my livingroom light on/off.
Is it possible to use the fiabro dimmer module with this lightswitch?
If it is possible: can i dim both lights individually with one module or do i have to put two modules in the 50mm socket? Will it fit?
No, is not possible, you can't connect two different light on one device.
you have to use 2 dimmer moduler or one 2x1,5kw relay. If you want to dim both, then yes- two dimmers are needed. If you cannot fit them both behind the box - then you can install one of them next to the light and associate it with S2 to dimmer which is installed behind switch.
Lauri
