richo 4
When you change a device ID i.ex. you replace a faulty device there is always an issue where you have used that device in all scenes. Unfortunatelly http call .../api/scenes is not a solution.
Here is a proposal how to get it done without the need of checking each individual scene code.
Create a virtual device with the following code and run it. It will send you an e-mail with the list of all scenes were the ID (or any other pattern has been used)
