power measuring on a virtual device
Guest MarkJ
HI
I'm looking for a solution for my power measering.
I have several devices that use a constant amount of W (server switch ect) I would like to add that power consumption to the total per room.
I want to create a virual device that has 2 buttons
1) on
2) off
Up till here no problem
Now I want to measure the power used as if it was a fibaro powerplug.
If "on" power consumption is 23 Watt
if "off" it is 5 Watt
When this is to complex then off 0 Watt is oke
Who can help me in creating this device including power measuring
Is there an alternative way to add constant used power to a room (a clock radio uses 3 W per hour)
Br Mark
hi
did you manage find what you needed?
I'm looking kind of the same
thx
It is not possible to include your own measurements into Consumption Panel if that is what you are looking for.
