Hi, I'm new in using Fibaro. especially in LUA. Is there a dummy guide for a beginner like me to learn about LUA coding? Thanks in advance.
Hi
Have a look to the following links :
Regards
I'am also looking for an overview of the fibaro calls in Lua. (like fibaro:debug etc). Is there an overview of those functions?
thanks
    Thanks for the link! I've started working on a virtual thermostat controller for my Split Type AC. Am on my way to finishing it today..
    Would like to know, if it works perfectly. Please share the lua code
    Sorry, I'm unable to upload the attachments on how I made the controller now.
    Yep, It's working already. I will upload all the data I made as soon as the maintenance is finished.
    [ Added: 2013-11-10, 18:03 ]
    I didn't use coding for the entire function. I could if I wanted to but I haven't learned some of the codes and the their syntax yet. Also, I wanted to make things simple first so my partner can also understand the process I've done.
    The equipment I'm using is Fibaro HC2 and Global Caché wf2ir
    Basically, what I did first was put all my IR codes in one virtual device "GREE" as seen in "IR codes.jpg".
    from there, I used another Virtual device to call upon each button whenever I change the status of the Thermostat. So, instead of using an array as the source list of my IR codes, i did that.
    This is the code for Power Button.
    %% autostart
    %% Properties
    %% Globals
    xPower
    xNumber
    xSpeed
    local xPow = fibaro:getGlobalValue("xPower")
    if xPow == '1' then
    fibaro:call(16, "pressButton", 1)
    xPow = 0
    fibaro:call(17, "setProperty", "ui.Label1.value", "OFF")
    else
    local xNos = fibaro:getGlobalValue("xNumber")
    local xSpd = fibaro:getGlobalValue("xSpeed")
    local xValue = xNos + xSpd
    fibaro:call(16, "pressButton", xValue)
    xPow = 1
    local xVal2 = ""
    if xSpd == '0' then
    xVal2 = "Fan:Low"
    if xSpd == '1' then
    xVal2 = "Fan:Med"
    if xSpd == '2' then
    xVal2 = "Fan:High"
    if xSpd == '3' then
    xVal2 = "Fan:Auto"
    local xVal1 = 0
    if xNos == '2' then
    xVal1 = 16
    if xNos == '6' then
    xVal1 = 17
    if xNos == '10' then
    xVal1 = 18
    if xNos == '14' then
    xVal1 = 19
    if xNos == '18' then
    xVal1 = 20
    if xNos == '22' then
    xVal1 = 21
    if xNos == '26' then
    xVal1 = 22
    if xNos == '30' then
    xVal1 = 23
    if xNos == '34' then
    xVal1 = 24
    if xNos == '38' then
    xVal1 = 25
    if xNos == '42' then
    xVal1 = 26
    if xNos == '46' then
    xVal1 = 27
    if xNos == '50' then
    xVal1 = 28
    fibaro:call(17, "setProperty", "ui.Label1.value", xVal1.."° C - "..xVal2)
    fibaro:setGlobal("xPower",xPow)
    Note: the (0, 1, 2, 3) references are for the fan speed
    0 = low
    1 = medium
    2 = high
    3 = auto
    and the (2, 6, ....., 46, 50) is the temperature settings from 16° to 28° C..
    (Please See 'Data Table.jpg')
    the numbers are the button numbers for the IR Code device. It what I call to send the IR through the transmitter.
    I know I could have used a simpler code in the comparison by using the FOR statement or other looping statement, but I haven't learned it yet.
    Also, I'm using 3 global variables, try to see attachement.
    Decrease Temperature (-)
    %% autostart
    %% Properties
    %% Globals
    xNumber
    xSpeed
    xNos = xNos - 4 <------------------For Increase Temp, Just change to (+)
    if xNos < 2 then and condition to (> 50) ... xNos = 50
    xNos = 2
    fibaro:setGlobal("xNumber",xNos)
    local xVal2 = ""
    if xSpd == '0' then
    xVal2 = "Fan:Low"
    if xSpd == '1' then
    xVal2 = "Fan:Med"
    if xSpd == '2' then
    xVal2 = "Fan:High"
    if xSpd == '3' then
    xVal2 = "Fan:Auto"
    local xVal1 = 0
    if xNos == 2 then
    xVal1 = 16
    if xNos == 6 then
    xVal1 = 17
    if xNos == 46 then
    xVal1 = 27
    if xNos == 50 then
    xVal1 = 28
    and Finally, Code for the Fan speed
    Settings for Low Fan Speed:
    %% autostart
    %% Properties
    %% Globals
    xSpeed
    xNumber
    local xSpd = 0
    fibaro:setGlobal("xSpeed",xSpd)
    local xVal2 = "Fan:Low" <--------Just change text to med, high, or auto
    local xVal1 = 0 0=low, 1=med, 2=high, 3=auto
    if xNos == '2' then
    xVal1 = 16
    if xNos == '6' then
    xVal1 = 17
    xVal1 = 27
    xVal1 = 28
    Whew!. I hope that can help..
