Virtual Device Rows Clone
If you have a few rows of elements in a virtual device that you want to copy many time in repeating pattern this may help. I used it to clone my Alarm Clock controls so I can have 8 alarms with my copy of scheduler.
Did not replace all the strings but you could replace strings in msg element
put this in a button on a virtual device.
6 answers to this question
Getting lazy rob
/emoticons/default_laugh.png" alt=":lol:" />
Just kidding, could be useful. I wish i could be half as good as you on coding
/emoticons/default_icon_eek.gif" alt=":shock:" />
    It just gets tedious copying code. If only there were global functions
    /emoticons/default_icon_curve.gif" alt=":-/" /> I wanted 7 alarm clocks for flexibility.
    Thanks for the icon Jonny.
    Nice, I didn't think about that.
    Think I will bother to find and replace in the code next time.
    Btw, which alarm clock are you using as virtual device?
    Yes using virtual device based on Marco's (Ucciogenerale) virtual device code and the lua scheduler.
    I have just made some small tweaks to the code and Jonnny(Jompa68) has tested.
    Will post but it at some point but it involves a bit more setup than the normal scheduler as there are some ids to change and global variables to create.
