Trig Scene with Lili
Is there anyone who can help, I can not start a scene with Lili.
I can eas-ily trigger the device with Lili
Guest GG
It does work to start a scene from lili.
I have a scene with the name 'fram' and a turn on lili command of 'titta'.
When I say 'titta' the scene starts.
I had to reload lili-database from the configuration tab in the gui before it worked.
Source trigger type will be 'other' if you are checking that in your scene.
Regards
Ulf
I have a question about Lili and voice commands. Does She recognize rooms and lights somehow? I would like to use similar commands: Kitchen lights ON/off and lets say: All lights off/on (if leaving house etc.)
So the question is: can lily read from room names also or command has to include room name if I want to get specific? Also if you have different lights in kitchen, I would like to turn them ON/off sometimes together, sometimes only spot lights..
Regards
Ulf
Please can you give me some detailed information how you do this, I can't get a scene working with Lili.
Regards
Ulf
That's easy.
Add your commands to start and/or stop the scene in the same screen where you give the scene a name. Use lower case characters and the English language (works best). Every spoken word is interpreted in lower case. So "Turn Kitchen lights off" will not work, as "turn kitchen lights off" will work.
Next go to the configuration tab and reload the Lili database.
Next go to your app and refresh the data in the settings panel. Sometimes this step is necessary, sometimes not. Do it, just to be sure the Lili commands are available.
Now you can use your commands with Lili.
[ Added: 2014-03-24, 08:50 ]
Lauri, you have to make a scene first in which you turn off your kitchen lights. Then you can give this scene the command "turn kitchen lights off" or "turn kitchen spotlights off". Make a second scene where you turn your kitchen (spot)lights on. Btw, check what Lili understands, she always displays the command she undersstood. That way you will know what to write, i.e. "spotlights" or "spot lights".
Lili will not recognize rooms or sections unless you use them to start a scene (tried it, didn't work for me).
How do i get lilli to talk back to me like she does in the video?
She does my commands but she never talk to me
I use samsung s5
Device control and scene activation through lili
I use samsung s5
I also noticed this. When removing the app (be sure to remove the apps data also) and reinstal, then the Lili voicecontrol files are installed again.
Then Lili is on speaking terms again...
Removed and installed again, still no Lili talking tom me
Tried on my wifes s4 mini don't work there eater.
Did you removed the apps data?
Yes i removed appsdata.
Did the app installed the Lilli database again? (about > 120 Mb)
Yes took some time but its installed again
I installed the app some time ago on my (old) S2 and it worked the first time. After a while Lilli shut up...
I have bought a new S5 some weeks ago and I didn't installed the android app yet. I will try to do so this weekend. I'll report the results when done.
Please come back with the result of your new S5.
Now i have tried 2 S4 mini and my S5
Confirmed NOT working (S2 and S5)! It did work somewhere in the past, but I don't know when exactly (several moths ago).
To bad!
PS when com.fibaro map is deleted the fibaro app asks to download the voice-file again. Tried several times...
Maby someone at fibaro can help us with this matter?
I want Lili to talk back to me.
sonnyboy, on android phone it will start talk with next update, if you got tablet with android you can test last RC how it work with lili
Tanks A.Socha, now i can whait to the new release
i got 2 denver tablets and the are not compatible with the tab version
/emoticons/default_sad.png" alt=":(" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" /> the resolution is to poor on those tablets.
Tried the tablet on my S5 but id didnt work
