Razberry as slave / secondary controller
I started Using Z-wave using a raspberry pi with a Razberry module. Now I have a HC2 and the Raspberry is used for Rfxcom 433mhz devices. I am thinking about using the Razberry as a secondary / slave zwave controller to HomeCenter. Is this posible? How do I set it up?
Thank you and best regards
Håkan
Have you tried adding this as another hc2 from configuration panel? There you can insert IP address, but I am not sure if it works with anything ecxept HC2.
