How could I set the temperature offset of the sensor connected to the universal binary?
I have 3 sensor in the same room, but only one read a different temperature (3°C more than the others 2).
Thank you
I want to do the same thing. Using lua you can change the offset:
In this example I've taken 2 sensors that are averaged and then a 0,75 degrees offset compensation is added.
But then of course you need to create a virtual sensor and this is what I haven't figured out right now.
