remote to start a scene
i'm looking for a remote that works with the fibaro hc2 to start a scene.
which remote will work?
8 answers to this question
You can buy Aeon Labs Minimote DSA03202W, works great to start scene
    looks great, now looking for a store in europe thats sells it
    other ideas are welcome
    [ Added: 2013-11-10, 16:02 ]
    can you tell me how?
    the shop owner (that sells the remote) told me that starting a scene is not possible without lua code?
    corrrect. The Lua code is quite easy. Only need some standard code and then per button you can just start other scenes (these can be graphic ones). that's what I do often. Keeps your LUA scripts small. Les mistakes.
    Take a look at our guide on how to use the Minimote in HC2. This should tell you all you need to know about using it with scenes.
    It is relatively straightforward to use.
    thanks for the link
    my lua is still a bit rusty
    /emoticons/default_smile.png" alt=":)" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" /> (new hc2 user)
    Guest jschun
    I use the Z-wave.me Key Fob remote on my HC2 (3.571) and since this morning I'm starting scenes using the 4 buttons once the remote. Also see my post from this morning if you are interested.
    Hi
    the only problem I have with this remote is that the remote needs to be directly in range of HC2 to operate and being close to a powered Z-wave device (FGS-221, Double Relay Switch, which is in range of HC2) doesn't work.
    So, it's good to deactivate the alarm before entering the house if the HC2 is close to the entrance but it's not good to open a gate from your car...
    Any ideas on how to solve the problem? maybe with a ZWave Range Extender?
    Riccardo
    use fibaro expander
