RGBW Module with W as input
Guest Charly86
Hi All
I bought several RGBW modules for driving RGB led strip and this is working fine. I also used W output to control a dedicated White strip (so driving 2 strips, one RGB and one White) and it is working fine.
Now got some sensors and I would like to use W channel as input keeping RGB as RGB module to drive my strip.
Reading the documentation is technically possible with parameter 14 but there is no way to do it in the HC2 GUI, as soon as I select input/output in HC2 I loose RGB functionnaly and if I set up as RGB module I have no option for the White channel.
Does I forgot something ?
Thanks for your help.
