FGD-211 dimmer V 1,9
Guest lepro4
I have force the update but this helps nothing directly at the module pressure switch connected between Sx and S1 is not responding lamp continues to light up max, I can also send nothing from hc2 's to this dimmer v1.9.
I place in the same configuration a dlmmer v1.7 everything works.
I sit now with 2 new dimmers v 1.9 which didn't work.
Can i reset the dimmers v 1.9 ?
lepro4, No you can't, but as far as I know, Fibaro will replace them or reprogram them if you contact support and send them devices.
You can actually reset them, I did it on mine to after I had short-circuited one of them.
From the manual:
Reset by holding B button for 3 sec. or within 5 sec by single pressing the first
key S1, and then by holding the second key S2. after connecting mains
voltage.
Having the firmware changed is something that only Fibaro can do on the older firmwares. All my dimmers are v1.9, but since I've only experienced problems with my Zipabox and not with the Fibaro anymore, I haven't send them in for an update. It probably means you can't use them for a couple of weeks, which is not something that's easy to do.
