where does alarm frame originate
Guest Kuuno
if i get an alarm frame eg. dimmer blinks on/off constantly .how do i find out the cause? this is not left in the log, but any way to track?
thanks
7 answers to this question
I have a PID controlled coffee machine on a fibao wall plug that was causing false alarm type behaviour. Something to do with the pulsing of power by PID and reporting of power I guess.
Is this what you are seeing?
I fixed by changing params on wall plug.
Guest Kuuno
    Not sure if it is the same. I have one light that receives somearm and starts flashing. Only 1 light and it happened twice
    Guess if it can happen from packets intended for power reporting... other packets could be misinterpreted on the network if the light modules are open to it.
    What i never understood was when i set the lights to not to respond to alarms they still flashed.
    Guest Kuuno
    +1
    We should open the bug again... What version of light module? Can you add your symptoms.
    Guest Kuuno
    this is happening again.
    latest dimmer versions and soem relays.
    need to find out what send alarm frame and how to stop
