Température control with IPhone
Hi
Is it possible to control home temperature with iPhone app without using timer ?
I can't change programmed temperature for all the week, only for next 6 hours.
4 answers to this question
You can use holiday mode and virtual device - then you can use slider to choose which temperature you want. There is LUA examples in here, use search and "holiday mode".
Lauri
    Hi Lauri
    Do you have direct link, there are too many message with "Holiday Mode" in search mode.
    You have to create virtual device :Holiday mode lets say
    IP is HC2 IP and port is 80
    then make a slider and add LUA
    change heating ID to what heating panel you want to change and insert your HC2 IP and login/password
    local new_temp = _sliderValue_;
    HC2 = Net.FHttp("192.168.1.72",80)
    HC2:setBasicAuthentication("admin", "admin")
    -- get harmonogram
    response ,status, errorCode = HC2:GET("/api/panels/heating?id=6")
    jsonTable = json.decode(response)
    -- change tabele in Lua
    jsonTable.properties.vacationTemperature = new_temp;
    -- send back
    json = json.encode(jsonTable);
    HC2:PUT("/api/panels/heating?id=6", json)
    fibaro:log("ready")
    Thanks Lauri
    It's working perfect, perhaps this can be implemented in next HC2 firmware or something better ?
