Use Z-wave.me controller 06443 as scene controller
I have included the z-wave.me 06443 wall controller in my network. The HC2 is the primary controller and the 06443 shows in the HC2 as a device of kind: Remote controller.
I have also added the parameter 13, data type 1d, value 1 and parameter 14, data type 1d, value 1, but I am unsure if that was necessary
I did not want to make any association with this controller and my other devices, I just wanted the 06443 to be able to start some scenes. To do that I was expecting to be able to select the some triggers on the device while editing a scene. However I can select the device in editing a scene (using the blocks interface), but only with conditions like ON, OFF Opened, etc. None of these conditions seem to triggered by a UP of DOWN click on the wall controller.
I seem to miss some understanding, who can help?
Thanks,
Wilko
5 answers to this question
Try this LUA scene, it should show you sceneactivation ID-s if there is some. Add scene and look the debugging window, then press switch and have a look - does it show some ID-s. If not, then maybe your controller do not have sceneactivation functionality?
Change ID-s to yours
%% properties
20 sceneActivation
%% globals
local id = 20;
local name = fibaro:getName(id)
fibaro:debug(name);
ActiveSceneId =tonumber(fibaro:getValue(id,"sceneActivation"));
fibaro:debug(ActiveSceneId)
AFAIK you should use value "3" for parameters 13 and 14:
    Thanks Lauri, I haven't used lua, but I will switch over to it and try.
    [ Added: 2013-11-22, 19:45 ]
    Lauri,
    I tried your lua code (without the tonumber, because I think debug needs a string)
    but got no SceneActivationId's just:
    [DEBUG] 19:43:37: Zwave.me
    [DEBUG] 19:43:39
    Also with value 3 for parameters 13 and 14 , still no response
    but I am pretty sure the controller had sceneactivation functionality
    any suggestions?
    [ Added: 2013-11-23, 23:37 ]
    I read in another post (
    ) that the HC2 has not implemented SceneActivation for the duwi zwave.me controller. So that explains. I hope Fibaro comes with a fix in the near future.
    Well I'm also down that road... Fibaro please
    If you want help from Fibaro side - please write to [email protected] -they do not visit forum every day or maybe just not every topic.
