Lauri 6
Hello, can you help me to find a problem here.
What is should do: It shold calculate
target2 - outTemp > hysteresis and then decide wether it needs to rise temperature or lower it. If rise, then it has to add to valve (roller shutter module) position 1% and wait for 10sec, if needed then open more 1% and so on.
What it actually does:
Everything is OK, but opening and closing the valve is not 1% and 10sec interval instead it opens valve 10-20% in one sec and this is not good.
What is wrong with LUA here?
%% autostart
%% properties
163 value
203 value
23 value
%% globals
targetTemp1
local extTemp=tonumber(fibaro:getValue(23, "value"))
local outTemp=tonumber(fibaro:getValue(163, "value"))
local ventiil=tonumber(fibaro:getValue(203, "value"))
local target2=tonumber(fibaro:getGlobalValue("targetTemp2"))
local hysteresis=tonumber(fibaro:getGlobalValue("hysterees"))
--local outtemp=tonumber(fibaro:getValue(36, "value"))
fibaro:debug(tonumber(target2))
fibaro:debug(tonumber(outTemp))
fibaro:call(202, "setProperty", "ui.lblTempout.value", outTemp)
fibaro:call(202, "setProperty", "ui.lblTarget.value", target2)
fibaro:call(202, "setProperty", "ui.lblTempExt.value", extTemp)
fibaro:call(202, "setProperty", "ui.lblVentiil.value", ventiil)
fibaro:call(202, "setProperty", "ui.lblHyst.value", hysteresis)
if target2 - outTemp > hysteresis then
--peab kütma
if ventiil<=99 then
fibaro:debug("kütame,erinevus: "..target2 - outTemp)
fibaro:debug("must HEAT")
fibaro:call(203, "setValue", ventiil+1)
fibaro:sleep(1000*10)
else
--fibaro:call(203, "open")
fibaro:debug("ventiil avatud :"..ventiil)
else
if ventiil>=1 then
fibaro:debug("jahutame,erinevus: "..target2 - outTemp)
fibaro:debug("must COOL")
fibaro:call(203, "setValue", ventiil-1)
else
--fibaro:call(203, "close")
fibaro:debug("ventiil suletud: "..ventiil)
--fibaro:sleep(1000)
Lauri
