hvb83 1
I've made a script that should switch another lamp if I press the main switch for that room. According to the level of the main lamp, the other lamp should be adjusted. That is, unless I manually control the secondary lamp. In that case it should stop adjusting according to the other lamp. As soon as I switch off the main lamp, the override is reset.
Basically everything is working. The lamps are interacting nicely, override is working and it is reset once the main lamp is switched off. Except for the 3rd elseif statement. For some reason the light won't be adjusted if "salontafel_status" get's over 50%. As far as I can see it doesn't deviate from the other 2 elseif statements, so I don't understand why it doesn't work.
What is wrong here? I was so proud finally having written something a little more advanced than "Hello world!" now...
/emoticons/default_icon_wink.gif" alt=";-)" />3 answers to this question
